- Warthog cnc ball screw repair
I have discovered that my router is loosing steps due to binding in the ball screw on the x and y axis. The machine is a 4x8. Should I clean/ repack them or just buy new drop in units
Re: Warthog cnc ball screw repair
hi,
wir setzen diese normal in stand. ich denke das findest du auch bei dir in deinem land. wo kommst du her?
- You may not post replies
- You may not edit your posts
Forum Rules
