- Mori Seiki SL2500 X axis ball screw replacment
Hey folks, need to find access to the lower thrust bearing block at the bottom with the 3 angular contact bearings and the nut at the end of the ball screw. A large saddle block is situated between the ways covering the area where this should be accessed. Please advise, thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
