It most likely look like the driver just stop supplying the pulses fo a reason. so the motor just stop without any deceleration that look like a shock.
If this is the reason, you have to investigate on the why this rebellion from your drive. Could be the controller that get lost because of the high speed, the drive that go into an alarm mode or anything.
video might help if you can get some
