- Problem with ballscrew?
Gold Member
Re: Problem with ballscrew?
Particle bard is not a good support. I think once you get it bolted into the machine with the nut secured as well, most of the issues will dissipate. The end run out is probably okay as well. This is why most couplers have some allowance in them for play.
Install it and then do some checking. My bet is that it will be acceptable. Your biggest concern then might be whip at speed on the screw.
- You may not post replies
- You may not edit your posts
Forum Rules
