Originally Posted by
Mavigogun
I have misgivings about mating Avid aluminum extrusions to a steel table. Part of the draw of Avid is that it's not a big, impractical to move machine- something it also suffers for. I'm seeking a middle ground, that space of compromise usually occupied by mediocrity. I want a relatively rigid table base I can break down and move, assemble, re-level, fill with sand for dampening, and build out the Avid machine base on.
I'm good with all the basic fabrication of the steel elements, but can't quite reckon how to wed the aluminum extrusions in way that will both allow for tramming AND capture the benefits of the steel base. I'm sure this is a problem that has been confronted by many others before- any insight will be appreciated.
