Hello everyone. I need some help. My spindle will not come up to speed. It turns on but will not increase rpm’s. Using Mach 4 software. On the screen it shows the RPM change. But the spindle speed doesn’t change. It worked fine 4 days ago. If you would please let me know your thoughts on this. Thank you
This is what I found. From what I can figure out the red and black wire are my single 0-10v wires. With the spindle running I’m getting .18 volts. If I adjust the RPM on mach4. I’m still getting the same reading. I have a older machine break board is a CRP550. I have a attached few pictures. Thank you for the help
Yes the machine was working fine last week. Havnt made any changes to it.
Mactec54
Its a Delta VFD EL
Mactec54
