I suppose over a long time a spring might lose some of its spring, especially if being over stressed. But normally this would not be a problem that you would see if the spring is correct for the application. Besides, springs are pretty cheap.
Rack teeth pointing down helps keep the crap from building up in the teeth.
Maybe your co-member had a bad experience with a spring at some time?
