I missed this post for some reason. So I have my new board wired and for the most part set to go but I wanted to ask a beginners question. On this C11G board the top row is for the relays and PWM. According to the docs it says pin 14 activates the relays so my question is, no wire actually goes to pin 14 or 16? Those pin numbers are to tell Mach right? and then when mach activates pin 14 it tells the relay on or off?? Lastly what config is given to Mach for the PWM? When I used the C10 board I gave an actual pin number but that is not present on this board?
A guy does a great video on this board and doesn't mention a word how to configure the darn thing.
http://cnc4pc.com/Tech_Docs/C11G-R9_USER_MANUAL.pdf
Also in Mach the only way I could get the spindle to run was to uncheck the PWM box and check the step/dir box? Sorry just a little confused on this one. I can not figure out what to tell mach or where to hook a wire up from the mach signal or does it even get on and at this point I am truly PWM?
I am using a Delta Fans VFD022EL21A VFD and
Ugra Spindle
Voltage: 220V/380V 3 Phase.
Current 9.7A/5.6A
Poles: 4
Frequency: 0~600 Hz
Speed: 0~18000 RPM stepless.
Manufacturer Recommended Working speed: 3000-18000 RPM
