Why get a Hypertherm generator and a different torch? No reason to mix and match. Just get the Hypertherm setup. That is what I did and it works great.
Sent from my iPhone using Tapatalk Pro
Hi There!
I have an Avid 5x10 dual Z-axis table (spindle and plasma).
I've got the spindle setup working and am currently building a vacuum table for routing. It won't be long and I will start in on the plasma portion of it.
I purchased the plasma kit from Avid and incorrectly assumed it included the plasma torch (not the whole plasma cutter, but just the long cylindrical torch head - I think Hypertherm calls it a "machine torch").
I have been planning on buying a PrimeWeld Cut60 plasma cutter and thought that the idea was to just connect the Hypertherm machine torch head to the Cut60 cutter.
I've emailed Avid back and forth. I ask about the torch and customer support is trying to sell me the entire Hypertherm plasma cutter (obviously, either I or they are misunderstanding).
The PrimeWeld Cut 60 includes a Euro Central Connection for the torch. What reasonably priced torch could I buy that would work with the Avid plasma torch mount and kit?
I found this on eBay. Is this an option? Is there something better?
https://www.ebay.com/itm/22377957314...MAAOSwqQpd6c~l
Thanks!
Avid CNCPro4824, Warp ESS, Nema 23 steppers, Delta VFD, 2.2kW spindle
Hypertherm Powermax 45XP with TMC3in1 THC
