Hi all,
I just slightly moved my machine for some workshop re-arranging, and decided to go through the whole re-leveling and tramming process with the new 4hp spindle - all looks good.
Then, I completed my spoil-board resurfacing and found a bothersome hiccup. I surfaced it with X-axis passes, and on one side the surface is super smooth as expected, but by the time it gets to the other end of the x-axis, the tramming is off (y-tramming) by quite a bit (I'll guess .005 in 1.75" surfacing bit stepover).
Any ideas? It's almost like the x-gantry has a twist in it, or the guide rail is uneven. Thoughts?
More likely if it's a new problem the table is not perfectly leveled?Hi all,
