Need to reinstall ESS
Results 1 to 5 of 5
Thread: Need to reinstall ESS
    Member brentphx's Avatar
    Mar 2021
    Default Need to reinstall ESS
    I tried setting up a USB hub so I only had one cable to swap to move my laptop out to the machine. I was fully operational and working beautifully using a USB ethernet adapter. I tried plugging the USB ethernet adapter into the usb hub and it was not found when loading Mach4. I removed the ethernet cable from the usb adapter and plugged it into the hub directly, it was not found when loading Mach4. I tried to launch the SCU application and there was only one adapter showing- the SmoothStepper Network static record. I selected it and clicked Configure Everything and it was not recognizing pings.
    I decided to go back to the usb ethernet adapter, so I moved the cable back to the adapter and plugged the adapter back into the single USB on the laptop. When I launch Mach4, it is not recognized. I tried using the SCU to reconfigure the adapter, but it says it appears I already have one configured. How do I delete or clear the existing driver so I can reinstall the ESS?
    Member ubergeekseven's Avatar
    Mar 2017
    Default Re: Need to reinstall ESS
    Open device manager. In the menu options choose to show hidden devices. Look through and delete the driver after that. Then it may recognize again.
    Sent from my SM-N960U using Tapatalk
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Do you have a USB Smoothstepper or an ethernet Smoothstepper (ESS)?
    I don't think that Mach4 supports the USB Smoothsteppers
    UCCNC 2017 Screenset
    Mar 2021
    I am using a usb to ethernet adapter and it was working just fine before I ran the SCU while it was plugged in via a hub.
    Thanks for the suggestion- I cleared device manager and it was recognized when I plugged in the USB to ethernet adapter. Same message when trying to run the SCU. I opened Network Connections and can see the SmoothStepper Network- I can disable it but the option for Delete is greyed out. I'm so mad at myself for running the SCU while plugged into the hub. Stupid mistake.
    Mar 2021
    Default Re: Need to reinstall ESS *Resolved
    **Solved**
    Avid support came right back with the ultimate answer at the bottom. After I reset my internet settings per their instructions, I still received the error message when running the SCU to set up the SmoothStepper. I checked in Network Connections>>Change Adapter Options to get to the Network Connections window and saw that the only remaining network was the SmoothStepper. Last time I checked here before the reset it was locked and I couldn't disable it but now I could. After disabling it and rebooting I was able to run the SCU and get pings. When I opened Mach4, I had full control again.
    Here's the email from Support:
    Thanks for reaching out, the only way to really delete the Smoothstepper connection would be to do a complete "Network Reset" however, it does have some downsides.
    The consequences of a full network reset are that ALL network adapters are completely set up from scratch again by Windows, so the SCU will need to be run again to set up the network for the CNC controller/Smoothstepper, but also any other saved network setting and Wifi networks / credentials, etc. will be removed, and will need to be reconfigured.
    A Network reset can be performed from the Setting app - you can most easily get to it by just searching for "network reset" in Windows:
    Select that option, which will take you to it in the Settings app:
    Just click Reset now, and then Yes at the following prompt.
    Your PC will then Reboot and your network drivers will be restored to default.
