I think I figured out the bulk of my problem - when I was zeroing out, I had not been changing the tool diameter in the Mach 4 dialog that appears. Now, I think that Mach 4 changes the diameter based on the g-code that is loaded, but often times I was doing the zero before I loaded a new set of code. I am going to experiment a bit and see what happens
