Helping our customer to assemble the 5 x 10 Feet 2KW Fiber Laser Cutting Machine
Our technician is helping our customer to assemble the Fiber Laser Cutting Machine. It is 3015H 2KW 5' x 10' Fiber Laser Cutter.
Check the product link: https://rb.gy/teuugn
Power: 1,000 – 6,000 watts range (1kW-6kW)
Working Area: 3000*1500mm or 118.11*59.06inches (5' x 10')
Numerical Control System: FSCUT2000
Passed CE/FDA/ETL certifications
2 Year Warranty
24 / 7 / 365 Technical Support
Introduction
SF3015H fiber laser cutter is mainly designed for the power :1kw to 6kw, it is with full-protection cover, which can prevent the laser radiation and protect the worker safety, reduce the environment pollution; and it is also with auto-exchangeable platforms, which can save the materials loading time, improve the processing efficiency. The exchange platform only takes 20 seconds to complete the exchange. The biggest feature of this machine is that the whole machine can fit into a 40HQ. No need frame container, which greatly saves freight cost. The sheet metal does not have to be dismantled for packing. It will save a lot of installation time.
Technical Parameters of Space Saver Fiber Laser Cutter SF3015H
Model Space Saver Fiber Laser Cutter SF3015H
Working Area 3000*1500mm/9.84*4.92ft
Laser Power 1kw/1.5kw/2kw/3kw/4kw/6kw
Power Source 380V?50Hz
X -axis Travel 1530mm/5ft
Y -axis Travel 3050mm/10ft
Z -axis Travel 220mm/0.72ft
X/Y Axis positioning accuracy ±0.05mm
X/Y Axis repeated positioning accuracy ±0.02mm
Maximum Velocity of Movement 130m/min
Maximum Acceleration 1.0G
Advantages of Space Saver Fiber Laser Cutter SF3015H
1.Smaller Footprint, Wider Working Area
Machine size is 2270mm*8300mm *2340mm,the floor area is 22.2% less than before.
The whole machine can fit into a40HQ.
No need frame container, which saves freight cost.
2.Safe and Stable Operation
720° all-round safety inspection, follow up the cutting situation in time.
Fully protected enclosed, reducing laser damage.
3.High Degree of Automation
Autofocus Laser Head, improving positioning and cutting accuracy.
Automatic gas distribution device for auxiliary gas.
1.High Strength Machine Bed
Welded with high-quality steel plates and pipes.
Annealing to eliminate internal stress
sufficient structural stability and shock resistance
Not deformed for a long time
2.Intelligent Surrounding Spiral Negative Pressure Partition Dust Removal System
Intelligently switching the air outlet, time-sharing, partition, and sectional air exhaust
Cooperating with the back-shaped sealing structure design at the bottom of the base to realize smokeless cutting.
3.Intelligent CNC Operating System
Adopt Cypcut numerical control system. With intelligent diagnosis, multi-threading operation, three-level perforation, laser energy control, adaptive edge-finding, automatic corner acceleration and deceleration, flight cutting, switching worktables, mechanical accuracy compensation and other features.
What’s the Industry Application of Space Saver Fiber Laser Cutter 4KW?
The SF3015H fiber laser cutting machine is specialized for sheet metal processing, machinery manufacturing, auto parts manufacturing, electrical manufacturing, elevator manufacturing, petroleum machinery, food machinery, decorative advertising, etc.
24 hours a day (mainly for international), 7 days a week, 365 days a year at any time to receive repair calls;
Within 10 minutes, technical engineers will consult, fix maintenance plan in one hour, and send engineers in one working day.
2. After-sale service
The seller provides one time free installation and training in buyer’s factory. Seller pays for the airplane tickets and salary for engineers, buyer should provide accommodation and food to engineers.
The seller will provide technical guide’s e-mail, telephone, WeChat, WhatsApp and so on.
The seller should pay for the travel expense if local service needed within warranty time.
3. Warranty
The warranty of laser source is 2 years.
The warranty of the machine is 2 years (main spare parts), except for the consumable parts such as ceramic ring, focus lens, nozzle etc. Warranty counts from the date marked on the label of the laser source and machine.
Except the damage artificially, seller is responsible for offering the fittings free of charge during the warranty period.
4. Worry-free
Pre-sale service: theoretical + practical operation training, self-diagnosis training for common faults, guidance for quick repair of difficult faults, and warning of matters needing attention in use;
Regular service: regular maintenance reminder, regular door-to-door service, regular promotional activities;
Value-added services: equipment software and hardware upgrading services, financial leasing services, delayed warranty service.
5. Field Service
Our branches in United States, Germany, India, Pakistan, Serbia provide localized services and technical support for global customers.
