3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine
Results 1 to 1 of 1
Thread: 3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine
    Default 3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine
    Testing 3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine -- EtherCAT Stepper Driver and Motors
    Product Link:
    https://www.automationtechnologiesin...tem-with-mach4
    Includes:
    -- 1pcs EtherCAT Motion Controller, Working with Mach4
    --3 Pcs NEMA 23 Stepper Motors (570 Oz-in) with 1.5 Meter Cable
    -- 3 Pcs EtherCAT Stepper Driver, EtherCAT Stepper Driver, EM3E-870E
    -- 1 Pcs 48VDc 12.5A Power Supply
    -- 3 Pcs Proximity Switch with 1.5 Meter Cable
    -- 1 Pcs E - Stop with 1.5 Meter Cable
    -- 1PCS 12Vdv Power Supply for the limit switch
    We can configure 4 Axis, 5 Axis, 6 Axis ..... to N axis
    We can change from 1.5-meter cable to other Length as you need
    Attached Thumbnails Attached Thumbnails 3 Axis EtherCAT NEMA 23 Motion Control System Working With Mach4 for CNC Machine-ethercat-kits-wiring-diagram-1024x1024-jpg
