- NEMA34 Closed Loop Controller 110VAC/220VAC, 1/2'' Shaft Size 1699 oz/in
Product link:
https://www.automationtechnologiesin...-110vac-220vac
3/4 Axis NEMA 34 Closed Loop Stepper Motor Controller 110VAC/220VAC
It works with Mach3 and Mach4
Pls email us, this is just a typical sample application, we can make as you need
FEATURES:
1: 1pcs Controller Box
BX4 - 600 x 400 x 250 mm Enclosure Box with side panel
2: 1pcs C82 Breakout Board
C82 - Dual Port Multifunction Board
3: 1pcs 6 Axis Ethernet SmoothStepper Motion Control Board
Connection to a PC. Runs with Mach3 or Mach4 on Windows 32 or 64 bit.
Ethernet SmoothStepper Motion Control Board for Mach3 and Mach4
4: 3/4 pcs Closed Loop Stepper Motor and Driver
NEMA 34 Closed Loop Stepper Motor System-Hybrid Servo Kit: 1699 oz-in 1/2'' Shaft Size
6: 1pcs 24V/2A power supply
24V/2A Switching CNC Power Supply
8: Miniature Circuit Breaker, 32A
8: Power cord
9: E-Stop and Power Switch
- You may not post replies
- You may not edit your posts
Forum Rules
