3 Axis 750W EtherCAT Servo Motor Kit with Mach4, 220VAC
Results 1 to 1 of 1
Thread: 3 Axis 750W EtherCAT Servo Motor Kit with Mach4, 220VAC
    Default 3 Axis 750W EtherCAT Servo Motor Kit with Mach4, 220VAC
    Product Link:
    https://www.automationtechnologiesin...h4-750w-3-axis
    EtherCAT Servo Motor Control System with Mach4, 750W, 3 Axis
    You can add a AC EtherCAT Servo Motor, Driver, Cable for 4 , 5 6, more axis
    No Power Supply, No Breakout Board are needed, Easy to wire
    Following Items are included:
    -- 1 Pcs Rebuilt Computer with 19 inch Monitor: 8GB of RAM, 500 GB Hard Drive, Windows 10 Pro x64 with One Year Warranty, If you need a brand new Computer, We can update to a new Industrial Computer for you
    -- 1 Pcs Mach4 CNC EtherCAT Software, License ( You can choose different Mach4 Screen) from Artsoft software
    -- 1 Pcs Kingstar’s RTX64 Runtime License and KINGSTAR EtherCAT License ( You do not need any Breakout Board, Ethernet board any more) from KINGSTAR
    --3 Pcs EtherCAT Servo Motors 750W
    Model Number: 750W ELM0750LH80F-SS
    -- 3 Pcs EtherCAT Servo Driver
    Model Number: ELP-EC750Z
    -- 3 Pcs Cable-7BMA5M0-Z "5-Meter encoder cable with battery"
    -- 3 Pcs CABLE-RZ5M0-S - 5-Meter power cable
    EtherCAT Servo Motor Kit, 750W 220VAC (750W EtherCAT kits with 5meter cable)
    If you need 3 Meter cable, pls let me know. (Cable-7BMA3M0-Z "3-Meter encoder cable
    with battery" , CABLE-RZ3M0-S - 3-Meter power cable)
    -- 3 Pcs Proximity Switch with 1.5 Meter Cable
    -- 1 Pcs E - Stop with 1.5 Meter Cable
    -- 1PCS 12Vdv Power Supply for the limit switch
    We can configure 4 Axis, 5 Axis, 6 Axis ..... to N axis
    We can change from 1.5-meter cable to other Length as you need
    Attached Thumbnails Attached Thumbnails 3 Axis 750W EtherCAT Servo Motor Kit with Mach4, 220VAC-6-jpg
