Testing Video:
For more details, please check the link.
Product Link:
https://www.automationtechnologiesin...-110v-12000rpm
The 600W spindle and driver kit is reliable and has high performance with low cost. This kit is developed to apply for hobby CNC router, it provides high speed up to 12000RPM with low noise.
This kit includes:
1.) 1pc 600W Air-Cooled Spindle
2.)1pc 600W Spindle Driver
600W Spindle KL-600BM:
Number of poles: 4
Phase to phase resistance: 0.61 Ohms
Rated torque: 0.55N-m
Rated speed: 12000RPM
Output power: 691W
Collect Chunk: ER11
600W Spindle Driver KL-600BD:
DSP main control module
No current passing when no movement
Voltage range 100VAC~120VAC
External independent panel
Maximum driver power 600W
5 debugging ways:Built in panel potentiometer?External panel potentiometer?external voltage signal?external PWM signal?485 communication.
Maximum driver motor running speed 12000R/Min
Speed testing port for user to inspect the real speed
Internal over-voltage, over-current and stalling inspection
Input signal TTL compatible
