Video 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4
Results 1 to 1 of 1
Thread: 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4
    Default 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4
    Product detail page:
    https://www.automationtechnologiesin...ema-23-cnc-kit
    We worked with Newfangled Solutions and KINGSTAR, built this new CNC EtherCAT Motion Control System. It is fully Pre-wired, tested and configured with Computer. So you do not need any Breakout Board, Ethernet Board. You do not need to wire them any more
    Following Items are included:
    -- 1 Pcs Rebuilt Computer with 19 inch Monitor: 8GB of RAM, 500 GB Hard Drive, Windows 10 Pro x64
    -- 1 Pcs Mach4 CNC EtherCAT Software, Licenseis included
    -- 1 Pcs Kingstar’s RTX64 Runtime License and KINGSTAR EtherCAT License from KINGSTAR ( You do not need any Breakout Board, Ethernet board any more)
    --3 Pcs NEMA23 Stepper Motors (570 Oz-in) with 12 feet Cable
    -- 3 Pcs EtherCAT Stepper Driver with 12 feet Meter Cable
    -- 1 Pcs 48VDc 12.5A Power Supply
    -- 3 Pcs Proximity Switch with 1.5 Meter Cable
    -- 1 Pcs E - Stop with 1.5 Meter Cable
    -- 1PCS 12Vdc Power Supply for the limit switch
    We can configure 4 Axis, 5 Axis, 6 Axis ..... to N axis
    We can change from 1.5-meter cable to other Length as you need
    Attached Thumbnails Attached Thumbnails 3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4-ethercatkit-jpg   3 Axis EtherCAT NEMA 23 CNC Motion Control System with Mach4-ethercatservomotor-1024x1024-jpg
