4? X 4? FIBER LASER METAL SHEET CUTTER 1000 W, 2000W, 3000W
Results 1 to 1 of 1
Thread: 4? X 4? FIBER LASER METAL SHEET CUTTER 1000 W, 2000W, 3000W
    Default 4? X 4? FIBER LASER METAL SHEET CUTTER 1000 W, 2000W, 3000W
    Pls call us at 847-984-0882 for any question
    Product link:
    https://www.automationtechnologiesin...tter-machine-2
    1000W: Carbon Steel: Max 12mm, S. Steel: Max5mm
    1500W: Carbon Steel: Max 14mm, S. Steel: Max 6.5mm
    2000W: Carbon Steel: Max 16mm, S. Steel: Max 8-9mm
    Machine with 3000 W laser Power will have high Price
    Specification:
    Working Area: (1300 mm x 1300 mm) 51" x 51 "
    Z-axis Travel: 4.7" (120 mm)
    Continuous Wave fiber laser, 1.07 um wavelength
    Laser Wattage: 1000 W/ 1500 W/ 2000 W/ 3000 W
    Beam Quality: <0.373 mrad
    Positioning Accuracy: <= 0.05 mm/m
    Max. no load speed: 3200 inch/min (81m/min)
    Machine Power Supply:Three Phase 208V, 240V or 480V
    Power consumption: 10-30 kW (various by laser wattage)
    Dedicated USA technical support from qualified technicians and engineers
    Gross weight: 5,500 lbs
    Air-Assist: Oxygen or Nitrogen
    Driving System: Servo Motors XYZ Servo Motors:Schneider or Delta, Y 2x850W, X 1x750W, Z 1x400W
    Unparalleled versatility for cutting various metals, including low carbon steels, stainless steels, galvanized sheets, as well as some high reflective metals, such as aluminum
    Long Durability (Cast Aluminum Beam, High Temperature Annealing Solid Machine Bed)
    Fully Protected Enclosure
    Laser fully contained in fiber, no need for regular beam alignment
    Attached Thumbnails Attached Thumbnails 4? X 4? FIBER LASER METAL SHEET CUTTER 1000 W, 2000W, 3000W-02_1024x1024-jpg   4? X 4? FIBER LASER METAL SHEET CUTTER 1000 W, 2000W, 3000W-1313g-_12_1024x1024-jpg   4? X 4? FIBER LASER METAL SHEET CUTTER 1000 W, 2000W, 3000W-show-jpg
