Here's my wiring
I did the jumper wire on the eStop. But still doesn't work
Here's my wiring
Look at the jumper. It's in a different location than the schematic diagram, but is shows you have your bottom pins set to input instead of output. It looks like if you move the jumper to pins one and two, it will change it to outputs for your motor drives.
Yes I did reset the eStop port and pin
I actually have moved that jumper to output...
Last night I took out the breakout board to inspect it, I flipped it over and it looks like one of the circuits is fried if you look at where it says AC7 ,looks like there's something missing
