problem motors not moving - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: problem motors not moving
  1. #21
    Member rick027's Avatar
    Jun 2007
    Default Re: problem motors not moving
    I did the jumper wire on the eStop. But still doesn't work
  2. #22
    Jun 2007
    Here's my wiring
    Attached Thumbnails Attached Thumbnails problem motors not moving-20191001_204807-2-jpg   problem motors not moving-20191001_204826-2-jpg   problem motors not moving-20191001_204853-2-jpg   problem motors not moving-20191001_204748-2-jpg
    problem motors not moving-20191001_185917-2-jpg   problem motors not moving-20191001_204559-2-jpg   problem motors not moving-20191001_204630-3-jpg   problem motors not moving-20191001_204731-2-jpg
  3. #23
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by rick027 View Post
    Did you reset the Ports and Pins for the E-Stop and look to see if it is working
    Mactec54
  4. #24
    Jan 2010
    united states
    Look at the jumper. It's in a different location than the schematic diagram, but is shows you have your bottom pins set to input instead of output. It looks like if you move the jumper to pins one and two, it will change it to outputs for your motor drives.
  5. #25
    Jun 2007
    Yes I did reset the eStop port and pin
  6. #26
    Jun 2007
    I actually have moved that jumper to output...
  7. #27
    Jun 2007
    Last night I took out the breakout board to inspect it, I flipped it over and it looks like one of the circuits is fried if you look at where it says AC7 ,looks like there's something missing
    Attached Thumbnails Attached Thumbnails problem motors not moving-20191002_195001-2-jpg   problem motors not moving-20191002_210535-2-jpg
