CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)
Results 1 to 1 of 1
Thread: CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)
    Default CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)
    https://www.automationtechnologiesin...or-and-driver/
    Panel operation parameter setting:
    A: KL-2200_BLM Brushless Motor and Driver kit, 220VAC,:
    1: KL-2200_BLM Brushless Motor : 2200W (3.0HP) / 6000RPM/ 220VAC, Single phase , up to 6000RPM Brushless Motor, Shaft Size: 18mm
    2: KL-2260_BLM Brushless Motor Driver , AC 220VAC input for 2200W (3HP)
    B: KL-1100_BLM Brushless Motor and Driver kit 220VAC,:
    1: KL-1100_BLM Brushless Motor : 1100W (1.5HP) / 8000RPM/ 220VAC,Single phase , up to 8000RPM Brushless Motor, Shaft Size: 15mm
    2: KL-1100_BLM Brushless Motor Driver, AC 220VAC input
    One Year parts Warranty
    Panel Control:
    1?Run ---------- Bottom left Key
    2?STOP------------Top Middle Key
    3?Increase ---- --- Top Right Key
    4?Decrease ------- Botton Right Key
    5: Configure ------ Top Left
    Exchange between panel and 0~10v analog A: ?Panel operation parameter setting Panel speed settings are as follows three parameters, after the restart into the panel speed mode panel operation mode: (FN000 = d0012, Fn001 = 1, FN010 = 36,FN147=1 Displays the current panel setup speed, After set this, power off and Power on)
    Analog speed mode: ( FN000 = d0005, Fn001 = 0,FN010 = 3 Displays the actual motor speed, After set this power off and Power on)
    0-10v Analog Speed Setting :
    The following three parameters, after the restart into the analog speed and use the port to start and reverse speed
    <Press the “Mode” key when you see FN000, then press the “Set” key , you will see d0012, then press the “down” key to see d0005 ,then press the “set ”key>
    Fn001 = 0
    <now press the “mode”key when you see Fn000 then press the “Up”key to Fn001 then press the “set” key , you will see 1 press the “down” key to 0, then press the “set “key>
    FN010 = 3
    Displays the actual motor speed , change FN147=0
    <then now press the “mode”key when you see Fn000 then press the “Up”key to Fn010 then press the “set” key , you will see 36 press the “down” key to 3, then press the “set “key>
    Step by Step, then will change into 0~10V use
    FN220: 1040 ( 0 to 5 VDC Control)
    FN220: 520 ( 0 to 10 VDC control)
    Attached Thumbnails Attached Thumbnails CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)-1100wconnection-jpg   CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)-92-1100w-jpg   CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)-130-2200w-jpg   CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)-1100w-jpg
    CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)-2200w-jpg   CNC Milling Spindle Kit 2200W (3.0HP) or 1100W (1.5HP) (Brushless Motor and Driver)-1100wconnectionp-jpg
