2: 3 .2 KW Water Cooled Spindle + 3.2 KW 400Hz Variable Frequency Driver
3: We changed this Machine to Mach3 or 4 Control , DB25 Breakout board with Relay and Spindle control with Ethernet You can use 32 bit or 64 bit connection. or we can update to Centroid Software
4: Mach3 Software is not included
X,Y axis working area
1300mm*2500mm (51.2" x 98.4")
Z axis working area
200mm ( about 8")
Table size
1440mm*3000mm
Max. speed
14m/Min
Max. working speed
12m/Min
Working accuracy
0.01mm
Repositioning accuracy
0.05mm
Feeding height
120mm
Command code
G code
Software
working with Mach3 software with Windows 64 or 32 bit
Working power
4000W
Working voltage
AC220V/50HZ/60HZ
Water Cooled Spindle power
3.2 KW
Spindle running speed
8000-24000
Spindle Power Motor: 3.2KW, Water-Cooled, ER20 Collet Chuck
Spindle Speed: 0-24000 rpm With VFD, AC220V/50Hz/60HZ
X, Y, Z axis driver: Stepper Motor Driver, NEMA34 Stepper Motor
X, Y Z Limit Switch
E- Stop, Z Height Probe
X Axis: Rack Pinion
Y Axis: helical rack and pinion with 5:1 Gearhead, See Pictures
Z Axis 20m Linear Rail with 25mm Ballscrew
One year USA parts Warranty
Mach3 set up for kit and machine, Download here
Mach3 Setup (Mach3Mill.xml file) (12066)
Mach3setup (16095)
Mach3Tutorial (202728)
Start Up Procedure:
KL-Series CNC Manual (2177)
We will send you a paypal request for shipping fee difference
