https://www.automationtechnologiesin...rking-machine/
Now we have 20W, 30W,50W in stock.
If you need a Rotary Device, add $500
This type laser marker suitable for Gold, Silver, Diamond, Sanitary Equipment, Foods Packing, Tobacco Label, Beer label, Drink Label, Medicine Packing, Medical Equipment, Glasses and Clock, Auto Parts,Plastic&Paper Materials, The Electron,Hardware which with high request for depth,smooth, accuracy such as horologe, Mould, bitmap marking etc.
Check machine testing video here:
The machine come with a user-friendly software. It is compatible to CorelDraw, AutoCad, and Photoshop if you need handle more complicated art work. It's an excellent candidate for bar code printing and stainless steel engraving.
(1):
Raycus fiber laser module, life time is more than 100,000 hours for 30W and 50W fiber laser Machine
Maxphotonics fiber laser module, life time is more than 100,000 hours for 10W, 20W fiber laser Machine
Packing information of fiber laser marking machine :
Machine Size: 60x 22x52cm
Package Size: 91x83x163 cm
Net Weight: 30kg around
Gross Weight: 50kgs
Main specification:
Laser Source Fiber Laser
Output Power 10, or 20, 30W, 50W
Wavelength 1060nm
Beam Quality < 2
Repeat Frequency 10khz--- 100khz
Pulse Energy 2 mJ
Beam Divergence -0.3 to +0.3mrad
Laser Class IV
Resolution 18?
Repeatability 50?
Marking Scope 110mmx 110mm/ 175mmx 175mm (optional)
Linear Speed 800 character/ s
Marking Linear Speed ?12,000mm/s
Marking Depth 0.01 to 0.5mm according material
Min. Line Width 0.012mm
Min. Character Size 0.15mm
Repeat Accuracy ±0.003mm
Input Power 0.5kw
Electrical Source 110V 50/60Hz /4A
