4 Axis Stepper Motor CNC Router / Mill Electronics Kit, Gecko G540 (110VAC/220VAC)
Link:
https://www.automationtechnologiesin...110vac-220vac/
This is nearly plug and play --
1: the only connections required are two wires between the G540 and power supply
2: the AC power cord for the power supply, both of which are provided via convenient screw terminals.
This kit includes:
1: 1 pcs 48V 12.5A switching power supply (110VAC/220VAC)
2: 1 pcs Gecko G540 4 axis stepper motor driver, Current Version
3: 4 pcs High-torque Nema 23 1/4" shaft 381 oz-in stepper motors. These are optimized for the G540 at 3.5A current , KL23H2100-35-4B
4: 4 pcs High-performance flexible, motor cables 12 feet cables. No soldering
One side wired with BD9 connector, one side wired with motor plug
One year warranty
You can update to a USB or Ethernet Board
- NEMA34 1128 oz-in closed-loop stepper Motors 4 Axis CNC Kit (110VAC/220VAC) - No Longer Available
- KL-6090 with Vacuum Table, 36 x 24 inch Working Size, Can Run at 110VAC or 220VAC - No Longer Available
- 3 Axis CNC Stepper Control Box 110VAC/220VAC: - No Longer Available
- 110vac or 220vac on a lathe and mill --- when given the choice????
- 110vac single to 220vac 3 phase VFDs
