This machine runs at 110VAC or 220VAC, We add a step-up transformer, 110VAc to 220VAC (Optional add $100)
Brand New CNC Router Engraving Machine with USB Connection
2.2KW (3HP) Liquid Cooled Spindle + 2.2KW Variable Frequency Driver
We Changed this Machine to Mach3 Controlled System.
Machine Size: 960 x 1320 x 1200 mm
Working Size X,Y,Z : 650(x) 900 (y) 200mm(Z) ( about 25.6" x 36 " x 7.87")
Gantry Height: 200mm (7,87 inch)
Working Speed : 200 -300 IPM, Rapid Speed: 500 IPM
Resolution: about 0.002"
Mach3 Controller with Mach3 Demo Software (Mach3 License file is not included)
Spindle: 2.2KW, Water-Cooled, ER20 collet chuck
Water Pump With Tank
Spindle Speed: 0-24000rpm with VFD, AC220V/50Hz/60HZ
X, Y, Z axis driver: Stepper Motor Driver, NEMA34 Stepper Motor, 640 oz-in
Y axis has Belt Reduction 1: 4.5 ration
X, Y Z Limit Switch, E-Stop
3 axis USB Breakout Board, you can use at 32, 64 bit computer, Window 10, 8, 7 , XP
20 Taiwan Hiwin Rail and Guide
Wood Packing Size: 1380 x 1090 x 1400 mm
One year USA parts warranty
