KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch
Results 1 to 2 of 2
Thread: KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch
    Default KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch
    https://www.automationtechnologiesin.../?preview=true
    Working Size is 1300*2500*200mm ( 51.2 x 98.4 x 7.9 inch)
    Syntech-6M Control System
    China CC 9kW Air Cooling Spindle: 24000 rpm/min, Linear ATC with 6 Pieces ISO30 Tools
    Vacuum Table with T-slot & 5.5kW Air-cooled Vacuum Pump
    China 850W AC Servo Motor and Driver
    Helical Rack and Gear Box
    Fulling Brand 11kW Inverter
    France Schneider Electric Parts
    Japan OMRON Limited Switch
    German Siemens OEM Factory Cable
    Manual Control with Aluminum Oil Pipe
    Under- Voltage, Missing Item, Phase Sequence, Overload Protection
    Aviation Aluminum Alloy Thickening
    Machine Max. Travel Speed is 40 m/min
    Machine Size is 3300*2200*1750mm
    1800kg Weight
    220V 50/60HZ
    Double Winding Film Packaging
    One year Warranty
    Attached Thumbnails Attached Thumbnails KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-1-jpg   KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-2-jpg   KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-3-jpg   KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-4-jpg
    KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-5-jpg   KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-6-jpg   KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch-kl-1325l-7-jpg
    Default Re: KL-1325L ATC CNC Router 51.2 x 98.4 x 7.9 inch
    Here is some video
