KL-1325 ATC machine with 4 Axis
Results 1 to 4 of 4
Thread: KL-1325 ATC machine with 4 Axis
    Company Representative
    Oct 2005
    Items for Sale
    Default KL-1325 ATC machine with 4 Axis
    https://www.automationtechnologiesin...1-x-98-4-inch/
    Working Area: 1300*2500*300mm ( 51.2 x 98.4 x 11.8 inch)
    Air Colled 9.0kW ATC Spindle
    Circle 10-slot Tool Magazine with Hand Wheel
    Japanese Yaskawa Servo Motor and Drivers 750W
    Z Axis Servo Motor, Hand-type Brake Function
    Delta 11kW Inverter From Taiwan
    Pneumatic Material Alignment Pop-ups 2pcs for X axis, 3pcs for Y axis.
    Taiwan HIWIN/PMI 25mm Square Rails
    Heavy Duty Structure
    CNC Router Rotational Axis
    French Schneider Electric Component
    Vacuum & T Slot Table
    1 Set 5.5kW Free Oil Vacuum Pump
    Auto Oil Lubrication
    Tool Calibrator
    3.0kW Double Bags Dust Collector
    Japanese SHIMPO Reducer for X, Y Axis
    Mist Spray Cooling System
    Rotary device 125*2000mm
    One Year Parts Warranty
    Attached Thumbnails Attached Thumbnails KL-1325 ATC  machine with 4 Axis-kl-1325atc-jpg   KL-1325 ATC  machine with 4 Axis-kl-1325atc2-jpg   KL-1325 ATC  machine with 4 Axis-kl-1325atc4-jpg   KL-1325 ATC  machine with 4 Axis-kl-1325atc5-jpg
    KL-1325 ATC  machine with 4 Axis-kl-1325atc1-jpg   KL-1325 ATC  machine with 4 Axis-kl-1325atc3-jpg   KL-1325 ATC  machine with 4 Axis-kl-1325atc6-jpg   KL-1325 ATC  machine with 4 Axis-kl-1325atc7-jpg
    Registered pugsly's Avatar
    Jun 2015
    Default Re: KL-1325 ATC machine with 4 Axis
    What are the power requirements?
    Oct 2005
    Items for Sale
    at least 10KW
    *Registered User* RafaSP88's Avatar
    Oct 2018
    So a 220v 3phase circuit will work to power this machine?
