Kelling Dip Switch Orientation???
Results 1 to 13 of 13
Thread: Kelling Dip Switch Orientation???
    Member ny_racer_xxx's Avatar
    Mar 2012
    Default Kelling Dip Switch Orientation???
    I have KL5056's and the DIP's are either 1, or 0.
    The switches are labeled on or off.
    My assumption was that 0=Off and 1=On
    I had the stepper set for 10 steps per, as 1001 on off off on, but it was really slow no matter how I tuned it, I inverted the switch settings, ie 0=On 1=Off.
    So I changed it to off on on off, purrs like a kitten!!!!
    If have the current setting and 1/2 power set to the 0=Off and 1=On convention, should invert those also?
    I just don't want to burn anything up....
    CR
    Jan 2005
    Default Re: Kelling Dip Switch Orientation???
    Do you have a 5056 or a 5056D?
    The 10 microstep setting on the 5056 is on off off on, but the manual for the 5056D says 10 microstep is Off On On Off
    http://www.automationtechnologiesinc...5/KL-5056D.pdf
    http://www.automationtechnologiesinc...load.php?id=50
    Mar 2012
    I did read the manual....
    I have the plane ole 5056, not the 5056D.
    I had the motors tuned for a G540 (long story) which is 10 step per, and when I set the dips as per the manual for 10 steps, off on on off, it runs slow as hell no matter how it's tuned, set the DIPS on off off on, and they run the same as with the G540.
    So my guess is that they are inverted, just not sure if I should invert the current and idle DIPS also, prolly should....
    CR
    Mar 2012
    I confirmed it, the switches are opposite of the documentation and silkscreen on the drivers.
    The steps settings were a no brainer because after I set them opposite, they matched the G540 settings that Mach3 was tuned for and that's 10 steps per.
    The Idle matched also, because when set to the book 1/2 power at idle switch 4 is 1 or on, and the motors got hot, set to off, or 0, motors were cool.
    I also set the current to the opposite setting...
    Just a heads up, if the steps don't seem right, try the opposite settings...
    CR
    Aug 2016
    Quote Originally Posted by ny_racer_xxx View Post
    CR
    I also have same drivers..
    So are you telling me the driver itself is labeled wrong...
    Cause I am having one bear of a time getting the steps per correct in Mach
    Are the current setting wrong as well...if so how did you prove that..
    Sent from my SM-N910V using Tapatalk
    Mar 2012
    I thought I explained it pretty good????
    CR
  7. #7
    Aug 2016
    I just confirming. .
    Did the current setting backwards too..
  8. #8
    Mar 2012
    YUP
  9. #9
    Aug 2016
    YUP
    Dude you are a genius. .
    I have been screwing with this thing for 3 days trying to figure out if I had something wired wrong. . Mach 3 settings etc.. and you saved the day..
    I reversed mine and wham...
    Thanks for the post. .
    I called Automation Technologies yesterday.. all he wanted to do was charge me 100 bucks to remote in...
    And I bet he knows these are wrong...
    I know where I won't buy again..
  10. #10
    Mar 2012
    I'm far from an expert, well I smoke tested enough equipment to be a smart ass, glad I could help...
    I've had good luck with those guys, but you kinda have to know what you want... He swapped a G540 that blew up for free, didn't matter, they are all junk anyway...
    Enjoy...
  11. #11
    Aug 2016
    Enjoy...
    So you say they are all junk..
    the G540 too?
    I hear they are the the ****..
    I had to be budget oriented. .
    I now have to machine my Z axis.. I am upgrading a harbor freight mini mill..
    I am mainly wanting to build guns.
    That said I am going to have to learn a CAD Cam prg..
    What are you using
  12. #12
    Apr 2017
    Hi...i am a new user here. I have the plane ole 5056 with the motors tuned for a G540 which is 10 step per, and when I set the dips as per the manual for 10 steps, off on on off, it runs slow as hell no matter how it's tuned, set the DIPS on off off on, and they run the same as with the G540.I think they are inverted, just not sure if I should invert the current and idle DIPS also.
  13. #13
    Aug 2016
    Quote Originally Posted by LulaNord View Post
    They are all inverted..do opposite of what is labeled...
