I am trying to edit post process to turn coolant on after the first G0 and Z move for every tool. How should the code look to make that happen? Fusion 360 software on a Haas VF4.
[QUOTE=Antvillareal;2437744]I am trying to edit post process to turn coolant on after the first G0 and Z move for every tool. How should the code look to make that happen? Fusion 360 software on a Haas VF4.
Thank you[/QUOTE]
Depending on your Haas machine it already turns on with a tool change, this may not turn on when you want it so yes you can add it in to your code where you need it to turn on, normally it is not needed though
