Hi, I'm just getting my feet wet with Fusion 360 and GRBL as I build my CNC plasma table.
I drew up a simple shape and did the CAM work in Fusion360. I picked the stock plasma cutter in Fusion360 and the simulation worked fine.
When I went to post process the CAM into the GRBL laser cutter/plasma cutter post processor, I got an error saying "The CNC doesn't support the required tool/process. Only laser cutting is supported"
I switched the tool to the laser cutter, re-checked everything and it posts just fine.
I checked the Autodesk CAM updates and it's the most current version of the GRBL post processor.
I'm a bit stumped about what's wrong.
I hope that I can get a bit of guidance here...
Has anyone managed to get the GRBL post processor working in Inventor Cam. I am getting the same error as above "Error: The CNC does not support the required tool/process. Only laser cutting is supported." but in the Autodesk Library it states that the post processor does "Waterjet / Laser / Plasma". I have tried lots of different setting but cant get it to work. Any help would be appreciated.
