Post processor for fusion360 to mach3 mill
Results 1 to 5 of 5
Thread: Post processor for fusion360 to mach3 mill
    Member Rustyj's Avatar
    Aug 2020
    Default Post processor for fusion360 to mach3 mill
    Hi all,
    Have been struggling to find a post processor that is compatible with how we operate,
    That is, we have a post and arm machine that we wish to mill primarily 2+1 axis cutter programs with,
    The issue is this,we will be making manual orentation changes to the milling head,and will then use a master set up point for each change to maintain accuracy,
    Basically we have to generate cutter paths to mill an oblong form(your car) from the side, head change mill top,head change mill front,head change mill back,
    At each head change in orentation we will return to master point to 're reference,
    Any thoughts much appreciated
    Default Re: Post processor for fusion360 to mach3 mill
    Hi
    I can develop a post for you. Mail me at maniac.cnc@gmail.com
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    This one already solved on the Fusion Community, the 5axismaker Post Processor turned out to be the best with a couple of mods
    Aug 2005
    Engine Guy, is this new Fusion post compatible with Mach4?
    Jun 2008
    UK
    [QUOTE=MARV;2399884]Engine Guy, is this new Fusion post compatible with Mach4?[/QUOTE]
    There is already a Post Processor in the Library for Mach4 but you are welcome to try the 5axismaker.cps one
