Need Help! Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
Results 1 to 3 of 3
Thread: Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    Aug 2015
    Question Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    i have a CNC using mach4 and a warp9 ess and i have added a diode laser to it. i have made everything work but right now i have to manually modify the gcode to add in the laser gcode.
    i was wondering if anyone had a post processor for fusion 360 that is capable of outputting the warp9 ess gcode for the laser?
    these guys have one for vetric vcarve and it works great: https://jtechphotonics.com/?p=3851
    thanks
    Raptor
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    Attached is a Fusion PP for Mach from Artsoft, there are many Laser/Plasma/Waterjet Post Processors in the HSM/Fusion 360 Post Processor Library which can be found here :-
    https://cam.autodesk.com/hsmposts?
    Just type in Mach Laser in the search box and a list of them will open, take your pick
    Regards
    Rob
    Attached Files Attached Files
    Member Tigglebitties's Avatar
    Nov 2019
    I've got the same problem. it just won't work with mach 4. and I don't know how to edit the CPS file to make it work, there's no line in the code regarding laser or anything similar. I wonder if using a mach 3 plasma profile would work to output regular router code and manage to work with laser cutting paths?
