Need Help! Fusion 360 Post for NC studio needed thanks
Results 1 to 6 of 6
Thread: Fusion 360 Post for NC studio needed thanks
    Apr 2019
    Default Fusion 360 Post for NC studio needed thanks
    Hi Guys
    I"m hoping one of you may be able to help me ...I"m looking for a post file for Fusion 360 that will work with NC studio on my Chinese CNC router, any help is greatly appreciated thanks!
    Sep 2011
    China
    Default Re: Fusion 360 Post for NC studio needed thanks
    Hello
    The NCStudio is compatible with standard G code, here is an example generated by cutleader which works with NCStudio well. Hope you could find a post which generates similar code.
    N1 %00001
    N2 G54
    N3 G00 G90 G17
    N4 T1
    N5 S12000 M3
    N6 G00 X122.9112 Y77.4415
    N7 G00 X122.9112 Y77.4415 Z5.0
    N8 G01 X122.9112 Y77.4415 Z-18.0 F300
    N9 G01 X125.4112 Y77.4415 Z-18.0 F800
    N10 G03 X127.9112 Y79.9415 I0.0 J2.5 Z-18.0
    N11 G03 X127.9112 Y79.9415 I-25.4541 J0.0 Z-18.0
    N12 G03 X125.4112 Y82.4415 I-2.5 J0.0 Z-18.0
    N13 G00 Z5.0
    N14 G00 Z50.0
    N15 G00 X231.9267 Y118.001
    N16 G00 X231.9267 Y118.001 Z5.0
    N17 G01 X231.9267 Y118.001 Z-18.0 F300
    N18 G01 X238.3022 Y118.8133 Z-18.0 F800
    N19 G01 X238.2971 Y118.8535 Z-18.0
    N20 G01 X249.5221 Y118.8526 Z-18.0
    N21 G02 X258.4486 Y115.0287 I-0.1522 J-12.6863 Z-18.0
    N22 G01 X297.5648 Y76.1671 Z-18.0
    N23 G02 X297.5642 Y64.6659 I-5.6241 J-5.7503 Z-18.0
    N24 G01 X251.5905 Y18.6908 Z-18.0
    N25 G02 X238.1017 Y11.5646 I-18.1507 J18.0274 Z-18.0
    N26 G02 X173.8066 Y22.2399 I-17.4656 J93.7642 Z-18.0
    N27 G01 X144.8521 Y38.4964 Z-18.0
    N28 G03 X135.4712 Y41.5378 I-12.3433 J-22.0835 Z-18.0
    N29 G01 X24.2193 Y54.4908 Z-18.0
    N30 G02 X20.9065 Y85.5767 I2.0503 J15.938 Z-18.0
    N31 G01 X147.9071 Y129.5199 Z-18.0
    N32 G02 X175.1382 Y122.3929 I8.2316 J-24.1348 Z-18.0
    N33 G01 X204.095 Y90.3889 Z-18.0
    N34 G03 X242.8689 Y105.3405 I16.5001 J14.9624 Z-18.0
    N35 G03 X238.3073 Y118.7732 I-22.2778 J-0.0745 Z-18.0
    N36 G01 X238.3022 Y118.8133 Z-18.0
    N37 G01 X234.4067 Y118.317 Z-18.0
    N38 G00 Z5.0
    N39 G00 Z50.0
    N40 G00 X116.075 Y159.4294
    N41 G00 X116.075 Y159.4294 Z5.0
    N42 G01 X116.075 Y159.4294 Z-18.0 F300
    N43 G01 X118.575 Y159.4294 Z-18.0 F800
    N44 G03 X121.075 Y161.9294 I0.0 J2.5 Z-18.0
    N45 G03 X121.075 Y161.9294 I-9.475 J0.0 Z-18.0
    N46 G03 X118.575 Y164.4294 I-2.5 J0.0 Z-18.0
    N47 G00 Z5.0
    N48 G00 Z50.0
    N49 G00 X39.875 Y159.4294
    N50 G00 X39.875 Y159.4294 Z5.0
    N51 G01 X39.875 Y159.4294 Z-18.0 F300
    N52 G01 X42.375 Y159.4294 Z-18.0 F800
    N53 G03 X44.875 Y161.9294 I0.0 J2.5 Z-18.0
    N54 G03 X44.875 Y161.9294 I-9.475 J0.0 Z-18.0
    N55 G03 X42.375 Y164.4294 I-2.5 J0.0 Z-18.0
    N56 G00 Z5.0
    N57 G00 Z50.0
    N58 G00 X39.875 Y616.6294
    N59 G00 X39.875 Y616.6294 Z5.0
    N60 G01 X39.875 Y616.6294 Z-18.0 F300
    N61 G01 X42.375 Y616.6294 Z-18.0 F800
    N62 G03 X44.875 Y619.1294 I0.0 J2.5 Z-18.0
    N63 G03 X44.875 Y619.1294 I-9.475 J0.0 Z-18.0
    N64 G03 X42.375 Y621.6294 I-2.5 J0.0 Z-18.0
    N65 G00 Z5.0
    N66 G00 Z50.0
    N67 G00 X116.075 Y616.6294
    N68 G00 X116.075 Y616.6294 Z5.0
    N69 G01 X116.075 Y616.6294 Z-18.0 F300
    N70 G01 X118.575 Y616.6294 Z-18.0 F800
    N71 G03 X121.075 Y619.1294 I0.0 J2.5 Z-18.0
    N72 G03 X121.075 Y619.1294 I-9.475 J0.0 Z-18.0
    N73 G03 X118.575 Y621.6294 I-2.5 J0.0 Z-18.0
    N74 G00 Z5.0
    N75 G00 Z50.0
    N76 G00 X143.477 Y136.4794
    N77 G00 X143.477 Y136.4794 Z5.0
    N78 G01 X143.477 Y136.4794 Z-18.0 F300
    N79 G01 X137.05 Y136.4794 Z-18.0 F800
    N80 G01 X9.95 Y136.4794 Z-18.0
    N81 G01 X9.95 Y644.5794 Z-18.0
    N82 G01 X137.05 Y644.5794 Z-18.0
    N83 G01 X137.05 Y136.4794 Z-18.0
    N84 G01 X137.05 Y132.5524 Z-18.0
    N85 G00 Z5.0
    N86 G00 Z50.0
    N87 %
    Apr 2019
    Could you possibly send me the post file that created that code thank you.
    Sep 2011
    China
    The problem is that the post is different for different cam software. The post I have for CutLeader doesn't works for fusion 360.
    Do you have editable Fusion 360 postprocessor? It's better to have a post for mill machine, then it's possible to edit it and make it works for NCStudio control.
    Member Maroslav4's Avatar
    Apr 2015
    There you have it.
    Without warranty.
    Attached Files Attached Files
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Apr 2019
    thank you so much.....
