Need Help! Kmotion cnc
Results 1 to 2 of 2
Thread: Kmotion cnc
    Jan 2017
    Default Kmotion cnc
    I've searched with no luck. I'm in need of a fusion 360 post processor for kmotion. I have run across a few threads talking about KMotionCNC.cps, but can't find a place to download. Any help would be great.
    Member Jim Dawson's Avatar
    Dec 2013
    Default Re: Kmotion cnc
    The only real difference I see between the Mach3 post and the Kmotion is the persistent XYZ outputs.
    You can edit the Mach3Mill.cps in Notepad and make it a Kmotion.cps. Give it a try, you too can become a programmer.
    change these lines in the Mach3mill.cps:
    var xOutput = createVariable({prefix:"X"}, xyzFormat);
    var yOutput = createVariable({prefix:"Y"}, xyzFormat);
    var zOutput = createVariable({prefix:"Z"}, xyzFormat);
    to:
    var xOutput = createVariable({prefix:"X", force:true}, xyzFormat);
    var yOutput = createVariable({prefix:"Y", force:true}, xyzFormat);
    var zOutput = createVariable({prefix:"Z", force:true}, xyzFormat);
    Save as Kmotion.cps
    There may be some other changes required, but this should get you started.
Kmotion cnc
Kmotion cnc
Kmotion cnc
