Need Help! Depth Per pass problem from Fusion360 to Candle
Hello:
I'm very new in CNC and don't know if this will be a bit out of topic here, I really apologize if that's the case.
I'm trying to make some pieces from Aluminium and the pockets comes out well but, when I try to make a 2D contour to separate it from the plate it always goes to 3mm depth instead the 1.5mm I have specified.
Maybe I'm trying to put the depths with the wrong "tool", I'm using "Multiple depths".
In the simulation appears correct, can be it a problem with the post processor? (I use GRBL) May it be a problem between Fusion and Candle?
