Hi All, just wanted to pass this on - I was setting up a 3D part, and the 3D Adaptive Clearing function was taking too big of a radial cut on the first pass. What I found is I actually had to define (in the "Design" tab) where the stock was (yellow outline in the attachment) and then tell Fusion (in the "Manufacture" tab) where the stock was under "Stock Contours" in the "Geometry" tab of the 3D Adaptive Clearing function. To generate a toolpath, the "Machining Boundary" field had to ve set to "none".
I don't know why I couldn't gain control over the radial depth of the first cut without doing what felt like extra steps, but this was one wat for me to skin the cat.
Kind Regards,
Chris Allmond
Allmond Marine
