fusion360
Results 1 to 4 of 4
Thread: fusion360
    Member happycnc1234's Avatar
    Aug 2019
    Default fusion360
    Hello. the first image is a svg file created in Inkscape. the 2nd file is a outline of the svg file, i saved the outline image and imported it into fusion 360 to engrave but it won't do it just hogs out the middle. Is there a way to do this thank you for any help.
    Attached Thumbnails Attached Thumbnails fusion360-first-image-inkscape-png   fusion360-inkscape-outline-first-image-png   fusion360-fusion360-finnish-cut-jpg
    Default Re: fusion360
    What F360 tool and operation are you choosing?
    happyzone's Avatar
    Oct 2019
    Quote Originally Posted by TMToronto View Post
    Hello I'm using 90 degree v bit and engraving
    happyzone's Avatar
    Oct 2019
    I have tried tracing with no luck. My boader is 95x214x14mm
    Dec 2013
    Looks like Fusion thinks your outline is a solid. Try playing with Project. It should project the outline onto a surface that you can then engrave using Trace.
    Jim Dawson
    Sandy, Oregon, USA
    Community Moderator difalkner's Avatar
    Nov 2014
    Moved to Autodesk CAM forum where more F360 folks will see this. Nice looking guitar, btw!
    David
    Romans 3:23
    CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
    David Falkner - www.youtube.com/user/difalkner
    difalkner - www.instagram.com/difalkner
fusion360
fusion360
