Play with Setup settings: is it set cutting outside stock?.
Can be a little trial and error finding your ideal setup.
Are you highlighting the cutting area or just the line?.
If trying to cut the recess out you want to select the inner step rather than the stock edge.
For edge recesses I normally use slotting with ramping rather than contour.
