Machine: FV56A Fanuc MPX-200i control
Software: Fusion 360 with Cimco editing software
Problem: I'm trying to get the A axis working properly. The program runs well in Fusion 360 during simulation. When post processing the G code is incorrect. Instead of the Y axis staying put and the A axis rotating to carve out a radial channel, the Y and A axis both move and the endmill is often cutting at a sideways angle.
I'm betting its the setup of the postprocessor thats the problem but I'm not sure how to get around that.
Settings are: Autodesk Generic 4 Axis (A Table) and FANUC.
