Are you using personal version of Fusion? Then there are no rapid movement commands in the resultant gcode.
Sent from my iPad using Tapatalk
I'm using the circular boring with the use on simular or same size holes options. When moving from one the the next it uses the cutting speed which is very slow. How can I use a faster jog speed to move between holes?
The features being dropped from the free tier are:
Probing, 3 + 2-axis milling (tool orientation), multi-axis milling, rapid moves, automatic tool changes
Multi-sheets, smart templates, output options for drawings (print only).
Download options from public share links
Cloud rendering
Export options including F3Z, DWG, DXF, IGES, SAT, and STEP
Simulation and generative design
Unlimited active and editable Fusion 360 documents (10 doc limit).
Fusion 360 extensions
