Newbie Issue with fillet machinning using mach3 and fusion
Results 1 to 2 of 2
Thread: Issue with fillet machinning using mach3 and fusion
    Member remi2103's Avatar
    Jun 2020
    Default Issue with fillet machinning using mach3 and fusion
    Hello
    I run small wood job on CNC.
    I just got a new CNC which is controlled with MACH3.
    I was used to run a GRBL controlled CNC (Shapeoko)
    I post processed an existing cam i already runned on my shapeoko with the mach3mill post processor.
    everything was ok until i had to machin fillets.
    The fillets are not on the good place, like if flat part of my tool were ignored.
    I had no problem on my shapeoko with the same toolpathes.
    it is a 2D contour toolpath with fillet bit.
    anyone has a clue ?
    you can see différences fusion VS reality in the attached photos.
    thank you
    Remi
    Attached Thumbnails Attached Thumbnails Issue with fillet machinning using mach3 and fusion-fusion-jpg   Issue with fillet machinning using mach3 and fusion-mach3-jpg
    Jun 2020
    Default Re: Issue with fillet machinning using mach3 and fusion
    after verification i noticed that the tool tip diameter of my roundover bit changed by himself for unknown reason.
    all is fine with good setting.
    thank you
