I'm not sure if there would be an easy way to go about doing that or not? you could save each object as a component and save them individually then start a new design sketching a rectangle to represent your sheet then copy your components in one at a time and move them during the process since that is automatic at first when you first insert a component. when you move them just move your tops of your objects to where you want them on the sheet individually. but that's going to take some work to sort out.
