Is Fusion360 a good alternative to CAM in SolidWorks?
Results 1 to 3 of 3
Thread: Is Fusion360 a good alternative to CAM in SolidWorks?
    Dec 2005
    madagascar
    Default Is Fusion360 a good alternative to CAM in SolidWorks?
    I'm using an evaluation version of SW.
    I find the CAM in SW to be not as useful and intuitive as I'd like.
    Can anyone comment on the differences between the two software?
    I am doing relatively simple 2.5D and 3D machining.
    Sep 2016
    Default Re: Is Fusion360 a good alternative to CAM in SolidWorks?
    Yes, its a good alternative for your described use case. Go give it a download. It's free if you're a startup/educator
    Dec 2005
    madagascar
    Thanks Dub
