Adding M11Px/M10Px to a Fusion PP ? I tried to edit with HSM : Visual Studio ,failing
Hello group , i am trying to add M11Px/M10Px to a Fusion Post Processor to setup my laser trigger quick , I tried many ways to edit with HSM : Visual Studio and failing ...
I found PPs for other softwares like DotG , Aspire etc and they work fine to add the M10/M11 and it works with Mach3 but i didnt found PPs using the M11/M10 to prepare g-code with Fusion360...
I can see the other CAM softwares are using a .PP format of the PostProcessors but Autodesk is only using .CPS and it is waaaayyyy more complicated to add M11/M10 to every places when it is doing Rapids in between traces.
Am i missing a point? is there a way to add a script in between each moves G1-G0 directly into Fusion360 CAM instead of editing a post processor ? I am wondering why i didnt found any PP using M11/M10 , am i just too dumb ?
I would appreciate some help !
The .PP format is sooooo simple to edit !!
but trying to edit the .CPS post processor is just giving errors , even using the Autodesk HSM system i found to edit them and i followed tutorials ive seen...
Re: Adding M11Px/M10Px to a Fusion PP ? I tried to edit with HSM : Visual Studio ,fai
Bit baffled by your problem, there are anumber of PP already for Laser use, here is some code as an example, I just did two simple 2D contours and the code is here, is this close to what you need? It does generate an M10 and an M11 for the Laser On/Off and does simple G code for the X and Y moves !
The .cps Post Processor file that was used to generate the above code is attached here in a Zip file, simply open the Zip file and then copy and paste the .cps file into your "Personal" Post Processor Library.
So this is the part that will automatically switch M10 to 11 when power is on ? is there a way have the PP tell the P1 next to the M10 ? could i just replace the qFormat by a pFormat in the "conditional(power, qFormat.format(cuttingPower)));
adding
var pFormat = createFormat({prefix:"P", decimals:0});
i am so really getting confused in these text codings , when i tried to add lines of stuff in them they always reported errors and getting me lost ....
usually the laser power PWM is getting called by S in Mach3 , but on yours is a Q , would just replace the Q variable to a S in the PP ?
i just tried the code from your PP and it turns ON the laser just when traveling
Edit: just inverted the 10 with the 11 in the line 782 and it all works out not needing the P part of the M11/M10 .... jeeeesuuuussss that i lost many hours trying to integrate these things .... but NOT EVEN NEEDED !!! i feel such shamed by myself.....
