Can you cut this on a 4th axis??
Results 1 to 7 of 7
Thread: Can you cut this on a 4th axis??
    Jul 2010
    Default Can you cut this on a 4th axis??
    This is a 6mm key. Half round and half square. I have the 6mm keyway stock so the challenge is to round the 6mm top. Understand I could do it with a bull nose, but can you do this in a 4th axis rotary?
    Attached Files Attached Files
    Dec 2013
    Default Re: Can you cut this on a 4th axis??
    It could be done on a 4th axis, but I would just use a corner rounding cutter.
    Jim Dawson
    Sandy, Oregon, USA
    Member Mecanix's Avatar
    Aug 2019
    I would also do it as Jim suggested.
    4ax zig-zag is also possible although would require a great deal of support/stabilization for that long part. Think custom fixture, and/or additional features like center drilled hole to accommodate a tailstock/live center. By the time you are done your hourly-rate cost +20x the price of the cutter required for that job.
    Just easier to clamp it onto a 3ax vise and running two finish passes with a brand new/sharp R3 corner rounding cutter.
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Quote Originally Posted by FastFarmer View Post
    I agree with all the other posters, such a job would be easiest done with a simple contour and a rounding cutter, just pop it in a vise and a couple of rough and finish passes and job done.
    Yes it can certainly be done in a 4th axis but the fixturing required would take time and money to make.
    However if you are determined to use a 4th axis then have a look at the attached Fusion file I have done and if it is of some use as a pointer then go for it
    Can you cut this on a 4th axis??-key-mod-v4-jpg
    JFYI When I opened your file it was 60mm square and 700 mm long, some key that
    Regards
    Rob
    Attached Thumbnails Attached Thumbnails Can you cut this on a 4th axis??-key-mod-v4-jpg
    Jul 2010
    Quote Originally Posted by The Engine Guy View Post
    Excellent!! Challenge complete..
    Thanks!
    Jun 2008
    UK
    Thanks!
    Didn`t know it was a challenge, is there a prize ??
    Few of these would do it
    Although come to think of it most stuff seems to be a challenge with Fusion 360
    Regards
    Rob
  7. #7
    Jul 2010
    Here ya go... first prize.. lol. Although I think I've convinced myself it's not the way to do it!
