Inventor GCODE Post Issue Accumulating Error Circular Interpolation
For those that like GCode and like a simple challenge:....
I am using Inventor to generate some GCode (Linux Post).
I am performing some calculations and seem to keep running into a weird accumulating offset on my machine. I have done some manual calculations and I can definitely see there is something that doesn't add up. It seems to be on Circular Interpolation (G17 so X&Y). I have attached the code below.
My problem is in a facing operation where I perform a series of circular interpolations. The first few go amazingly well, landing exactly on point, however when it comes to line N115 I am out by 1.
It then seems to keep getting worse from that point.
Working through line N115, I have a starting point of Y: -52.874 (N105 is the last time YAxis value changed), i then cut a circle with an offset of 1.886 in the same Y-Axis. So theoretically I should land at -58.874 + 1.886 + 1.886 = -49.102 but the GCode states that I should land at -49.101.
Now I know most of you are going to say rounding, but with this precision there is no rounding.
How is it that the GCODE calculating -49.101. This means that my next instruction is off by one and keeps accumulating errors as it proceeds.
It is absolute programming but due to the fact that it is a facing operation with only circular interpolations affecting the Y axis value; it means that there will always be an error cause I have to take either my calculated value or use the calculated value in the GCode. If I use my calculated value then it means I wont match with the next circular interpolation value and if I use the GCode Y value then it wont match with the formula for a circle/arc.
Even when I use NCViewer to model the GCode I can see that it calculates -49.102; could it be that Inventor just doesn't calculate G codes correctly?
Re: Inventor GCODE Post Issue Accumulating Error Circular Interpolation
Well, I don`t think that you have anything to really worry about, the error is only 0.001 of a millimeter and is not cumulitive as once that line is the 0.001mm out all the susequent lines still do a 3.772mm step over so at the end there is still only a total of 0.001mm error.
It is possibly to do with the settings in your program, there will likely be a Tolerance setting that is possibly set too low and allowing the post processor to spit out these tiny differences, I don`t have Inventor so not able to check on the way the settings are done but have a look for the program tolerances and if it is for example to 4 decimals like 0.0001mm then try changing it to a more reasonable 0.01mm and see what you get then
As I suspect that that amount of 0.001mm is probably less than your machines control resolution and almost certainly less than your machines mechanical resolution which for most machines (Especially if it uses Stepper Motors) is only 0.01mm so those tiny differences will probably never be noticed by your control and will never affect a cut so unless you notice any future larger deviations then just carry on as normal.
You not out by 1. you are out by 1 micron (0.001)
you seem to be doing a facing operation..... does this error in the middle of a cleared area really matter ?
Is it giving an alarm while machining ?
It is a rounding error, a 1/2 circle Y move at the end of each X move.... if you really dug down deep... each position is probably calculated to 15 decimal places.. & the NC output is only 3 decimal places for metric, this shows up as the consistent rad size and the discrepancy with X or Y value. I would not be overly concerned with this error unless it stops the machine from running.
