Fusion 360 question
Results 1 to 6 of 6
Thread: Fusion 360 question
    Feb 2006
    Default Fusion 360 question
    Does anyone know if Fusion 360 contains an editing program/plotter(?) that allows verifying hand written code? New to CAD/Cam, and I want to purchase F360.
    I would like to be able to run my already hand written programs to check them for accuracy if possible to improve efficiency. Thanks in advance! Joe
    Dec 2013
    Default Re: Fusion 360 question
    No, no way to run a simulation of G code, you can only run a simulation directly from the CAM function in the program. But get Fusion 360 anyway, it's free to hobbyists, students, and startups making < $100K per year.
    Jim Dawson
    Sandy, Oregon, USA
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Quote Originally Posted by gunsmither View Post
    If you want to check your G codes you can do it here https://ncviewer.com/ for free, just open your code file and run it to see the toolpath, it isn`t a full 3D solids one but it does work well and it`s FREE
    Regards
    Rob
    Feb 2006
    Much appreciate the info fella's. F360 doesn't have the free gizmo's as far as I can tell, but I'll buy it anyhow for my business. I'll check out the NC Viewer also. Joe
    Jun 2008
    UK
    Joe
    FYI, I forgot to tell you that the NC Viewer can be "embedded" into Fusion 360 (Usually is to start with), so your G code can be backplotted within the Fusion work space, once code is produced it can be simply opened or "dragged and dropped" into the NC Viewer.
    Here is a link to the Fusion Tutorial that covers this Help
    Oh, and yes, there are lots of "Free Gizmos" like Helical Gear Generator, they are all in the "Fusion 360 App Store" here https://apps.autodesk.com/FUSION/en/Home/Index
    Regards
    Rob
    Feb 2006
    Thanks again Rob, you are most helpful! All the best to you sir. Joe
Fusion 360 question
Fusion 360 question
