Hi Terry, hope this helps you a little, see images below:-
On the simple block I created I "Double Clicked" on the edge I wanted to cut, a thin blue line appears on that edge and the rest are black and also the "open/closed" contour option appears, image 1.
Next I selected the "open" contour option
Next I clicked on the Green "+" symbol to accept the "open" contour option and this is what I get
Now I am able to cut only the edge I required, give it a try, my little sample Fusion 360 file is attached in a Zip file. Simulation image added
Enjoy
Regards
Rob
