Newbie Rounded edges on pocket finishing pass
Results 1 to 3 of 3
Thread: Rounded edges on pocket finishing pass
    Registered andrealuc's Avatar
    Mar 2019
    Default Rounded edges on pocket finishing pass
    Trying to carve/cut a wooden cat plate and want the pocket to have rounded corners on the bottom edge. So far, I have the roughing toolpath with a 1/4" upcut bit and want to use a 5/8" (cutting diameter) core box router bit for the finishing pass. How do I make the finishing pass? I'm using fusion360.
    Thank you
    Member precisionmetal's Avatar
    Oct 2010
    Default Re: Rounded edges on pocket finishing pass
    andrealuc,
    So am I understanding correctly that you are looking to create a 5/16" radius on bottom edges of your pocket? (where the floor meets the walls?).
    If you created the model that way, you could simply create your 5/8" ball end mill in the tool library, then create a contour pass using that tool, and you should be good.
    There are many other ways to accomplish that cut -- however I'm guessing a bit at "exactly" what you're trying to do. Also, knowing what machine you are using may help as well.
    PM
    Mar 2013
    If you rough with a flat bottom endmill, don’t forget to leave enough on the bottom for the radius at the bottom corners
    Sent from my iPhone using Tapatalk Pro
